Surprisingly compressor parts are very generic. Reed valves form one brand often fit others. I have some CH reeds in a Sanborn comp, direct interchange. Companies farmed out as much of the stuff as they could. As an example, it makes no sense to set a line to build pistons, when Briggs and Stratton make them all day. You might be amazed to learn some compressors contain small engine pistons. I needed a set of gaskets for an older CI sears comp, so I used Dayton from Grainger. They were made by CH.When you find one make sure that it runs and builds pressure in a reasonable time or the compressor may have reed valve problems. A replacement reed valve plate is usually about $130, if it is available. Other than the reed valves, very little goes wrong with these compressors, except rarely the pressure switch goes bad. A non Sears replacement pressure switch is usually around $40. Neither one of these repairs is very difficult to do IF you can obtain the parts.
Charley
