I will leave the review for others with that model, but if the cutterhead uses straight knives then they are inexpensive and easy to come by and not worth worrying about too much provided the cutterhead is in good condition otherwise, but if it is an indexed carbide helical/spiral head cutterhead then replacing all the carbide inserts can be a bit costly if the existing inserts are worn out (such are usually four sided) or physically damaged.
But, in general, an 8" jointer is a good general purpose jointer for most woodworking operations since the vast majority of work, and most lumber, tend to be 8", or less, in width. If you do not already have a thickness planer then you will want to also add such to your collection as both jointer and planer compliment one another, each performing a different but equally vital role in most shops.
