Hi all,
I finally finished a bench that has been a couple of years from conception. The NC Woodworking Showcase gave me the incentive to finally put a finish on the piece. I have included few photos.
The bench is of mottled makore and wenge. I had created a mock-up from cardboard to elicit comments before cutting this expensive board. The fear of cutting the board and not doing it justice took a few months to overcome!
The joints were cut by hand except for the mortises (router and mortiser). The parts were dimensioned by wide belt sander, jointer, and table saw. I had hoped to surface everything by hand, but I couldn't quite get the surface that I wanted. Not exactly tear out, but a little fuzz on the convoluted figure over a very small percentage of the surface. Weird wood to work in some ways. So sandpaper it was! Finish is General Finishes Seal-a-Cell and 5 coats of Arm-R-Seal. That will become 6 as I didn't like the finish in the raking light at the showcase. Note to self: get better lighting in the shop.
Tools used:
Marking gauges
dovetail template
dovetail saw
carcase saw for tenons
shoulder plane
marking knife
chisels
chamfer plane
block plane
cigar spokeshave
low angle spokeshave
low angle jointer plane
smoothing plane
The bright white between the wedge columns is just paper to show the detail for the pic.
Thanks for looking!
Tools used:
Marking gauges
dovetail template
dovetail saw
shoulder plane
marking knife
chisels
chamfer plane
block plane
cigar spokeshave
smoothing plane
Thanks for looking!
