Hi all,
A while back I posted some pics of the little LED flasher I built to put in my dust collector cyclone separator trash can. This gadget works fine for me except when I'm hogging off lots of material with the planer (like with soft maple or cypress) and the big shavings get stuck between the lid and the cyclone baffle. I never see anything blocking the LED because it's all up above in a big mess..with the shavings being dumped into the Grizz bottom bag, thus defeating the whole purpose of everything .:no:
The solution to this is to widen the throat of the baffle drop zone..which I did..and now all is fine. But a visitor to our site in Connecticut saw the "flash in the can" bit,(he is now actually a member) andi asked my advice on building a more elaborate sensor.
Folks with large cyclones (like Oneida) have seen the dust bin fill completely to the top and totally load the cyclone right up to the blower..these collectors are very strong and keep right on”sucking”somehow, even when no more chips can get in there. You'd think the motor would sound different, but I'm told it doesn't.
The guy in Connecticut has one of these and was trying to put some kind of sensor together to prevent possible overload. Oneida sells a sensor kit for $269 to monitor dust level that you have to wire it up to the 220V supply and install yourself.
http://store.oneida-air.com/levelmetersensor-prewiredkit.aspx
I suggested using the little photocell detectors used in electric garage door safety trips. The idea is to mount them on opposite sides of the drum at windows set at the fill level wanted. We also needed some delay so that random chips passing by don't trip the alarm, so a 5 second delay was designed into the circuit..in other words, the sending sensor has to be blocked continuously for 5 seconds before tripping.:widea:
Garage doors stop instantly if the beam is broken for a second or less.
Anyhow here's what we developed. The garage door sensors are Genie model STB-BL replacement units that you can get at most HD or Lowe's stores for about $35.00 . The circuit is packaged in a weatherproof (dust-proof) outdoor enclosure and a very bright strobe light is used for the alarm.
Here's the sensors looking at each other on the bench
You know when they're aligned..the sender glows green, the receiver glows red
Here's the box put together with the strobe light on top
...and here's what happens when the beam is interrupted for 5 seconds..
The strobe will flash continuously about once a second until the obstruction is removed..or you switch the power off. The whole thing is powered by a 12 volt "wall-wart", and the relay driving the strobe (which only draws a quarter-amp from the circuit) can supply at least 7 amps. So driving the magnetic switch on the dust collector to turn it off when the alarm lights is no problem at all.:icon_thum
We had the circuit assembled by Jeff Wheat at SimpleCircuitBoards.com,and he will sell the complete circuit board, populated with the components and tested, for $20.00 plus $6.00 Shipping. The strobe is from E-Bay and cost $9.97 delivered.
So for a total of about 70 bucks you have basically something that does pretty much the same thing as the Oneida sensor.:icon_cheers
I haven't tested this in real life yet, and it's way overkill for my little separators so I need a "lab rat" somewhere close by so I can help install it and watch it blow up.:nah:
I'm thinking Travis might want to try it out since he's already experienced a cyclone plug. Scott isn't up and running yet but this would work for him too.
Any takers?? :gar-La;
PS: I went into the shop this afternoon to get something and threw my baseball cap on the bench. ..without realizing it had landed between the sensors. Five seconds later it let me know !!!
Don
Don
