I'm in the process of building some end tables from walnut and am at the point of needing to decide what finish to use. In the past I have built some small boxes from walnut and used a process from Bob Flexner (I think) that he called "finishing the finish". Essentially it was sand to 180 or 220, 2 to 3 coats of shellac (the shellac was used as a filler as well as the top coat), wet sand with a MS lubricant 400 to 800/1000 grit. The pros of this process are that it gave a result I liked in terms of appearance and texture/polish. The cons are it is time consuming, difficult to do on an assembled project with lots of mortise/tenon joinery and and I'm not sure shellac is the best choice of finish for an end table.
Here is a picture of the project - nothing is glued up and the shelf/top/drawer are missing but it does show the joinery.
So my initial questions are:
1. What is a good finidh for walnut end tables?
2. What is the schedule/process in terms of pre-sanding, applying (no spray equipment available) and "finishing the finish"?
3. Can the process be done before assembly with appropriate masking?
I'm sure there will be many additional questions as the discussion evolves.
Thanks
Rick
Thanks
Rick
