work in progress, 1/6th 1890's navy steam launch built to navy plans
tghsmith
tghs
this project crossed a milestone (sea bouy?) today as the framework in completed,, fairing and planking to start next week.. no more steam bending frame billets,,
tghsmith
tghs
lots of scratchbuilt ships and boats using more normal model building methods,, this one has been in the planning for over ten years,, will be live steam, built directly as the the navy plans including wood types, I've been working on the engine and brass work for the hull for a while..
That's Awesome ! Is the little skeleton showing us what you will look like when you get done ? :D
tghsmith
tghs
some days it feels like that, but actually he is 12 inches tall making him 1/6th scale so shows the model size without blocking to much detail in the photos.. he is a stern inspector of parts..
Dee2
Gene
Thought maybe the skeleton was Davy Jones shriveled up.
tghsmith
tghs
back to making tools, size wise my sanding boards that I have on hand were not up to the job,, made some more (may have over did it!!) different widths, thickness and flex...
tghsmith
tghs
added handles to the big flexy sanding board (BFSB) speed things up, one side is mostly faired, more work around the stern and skeg needed.. but moving along nicely..
tghsmith
tghs
how to make a template for a complex shape,, I had some flexy plexy about the shop,, it formed well about the complex shape of the fantail stern,, marked it and cut out the templates,, cut out the billets out of white oak and re-sawn for thickness..after getting the blanks close to the final thickness and shape they will be heat bent to fit..
Dee2
Gene
Davey gonna need some deck shoes before long!
tghsmith
tghs
after months of cutting, bending, planning, rasping, carving and sanding the white oak for the framework turning the white cedar boards into hull plank blanks was a joy (not to mention it smells so nice) cut to height on the tablesaw and then rough thickness on the bandsaw.. the thin bandsaw blade allowed for 4 planks per billet with room for thickness sanding..
tghsmith
tghs
thanks all, things should get really fun when the cherry and ash work starts..
tghsmith
tghs
setting the curves in the white oak sheer planks,, a good hot hot water soak, a little help from the "bending iron" and lots of clamps..
tghsmith
tghs
most woodworkers has a wall of bar-clamps, I have a pile of small C-clamps
