Using Templates
JackLeg
Reggie
:eusa_thin:eusa_thin
How do most of you "attach" templates for cutting out with your routers? We need to cut quantities of identical pieces, and I have found no real good method so far.
All input is welcome.
If piece has a "blind side" that won't be seen, then THREE screws through the template. I always use three, because if one failed there would still be two holding assembly. Double stick tape is a PITA for me. If I were making several multiples, I would add some vacuum tape and a fitting to template. Place on stock, turn on vacuum and route away. Joewoodworker.com has best price on vacuum tape that I know of.
I like double stick "duct" tape. It is a little bit of PITA to work with but holds like the dickens.
JackLeg
JackLeg
Reggie
I have been using screws to this point. Has anyone ever tried a small amount of hot melt glue? I hate DS tape, :BangHead: it's a REAL PITA. Thanx for the input so far.
woodArtz
Bob
I'm a big believer in DS tape. My wife and I have used it extensively over that past few years for template work. Sorry, no help for you Reggie...
WoodWrangler
Jeremy
I've been using DS tape as well -- usually the "turners tape" from WC. It's strong and easy to peel ... though can be a PITA when it sticks really good.
If you are using screws, could you use several wire nails instead. extend them only a 1/4" past the template. Tap on, pry off. A small recess in the bottom of the template for the pry tool would speed it up.
Just a thought
Dutchman
Buddy
Gofor,
That's a common way to do it in most furniture factorys. Use a good 1/2 plywood form, drive in some nails slightly larger than finish nails, clip off the heads and file to a sharp point. They will hold your stock just fine in most situations. If you are getting crazy with the amount of wood you are removing, you might need additonal holding. Are you shaping all the way around? You can use a lever clamp (can't think of the brand name) to help clamp it to the form also.
User not found
Reggie,
Fellow NCWW member SteveD made a big order of Adirondak chairs several years ago and showed me the vacuum templates he used for pattern routing the cypress parts. It made the process very fast and left no scars on the wood. Each template simply had a weather seal tape around the perimeter and a 1/4" tubing connector to draw the air out between the template and the stock. All of the pieces were cut out on his router table against a starter pin using a pattern bit with the bearing running against the template side.
Sully
jay
I use DS tape and/ or hot glue.
1) There are several brands of DS tape though. Some work much better than others. The kind they sell at Walmart (can't remember the name) is horrible; it leaves a sticky mess that is hard to remove. At Lowes on the other hand they sell a brand (I think it's the 3M brand specifically) that goes on and comes off easily. I'm planning a Lowes run in the morning and will report back with the name brand I normally use.
2) Hot melt glue works well for a lot of applications. I sometimes use it for attaching temporary sacrificial fences on the TS or router table. It normally leaves no residue on the pieces and pops off easily with a plastic putty scraper or glue spreader. I find the hot glue works best if you put down several evenly spaced dots around the workpiece, rather than trying to lay down a thin bead over the surface of the workpiece. For template routing hot glue works fine if you are not hogging off a bunch of material.
Joe Scharle
I find that with DS tape, little pieces hold just as well as large patches and are a lot easier to pop off. The brand is important and lately I've been using the stuff from Woodcraft. Before DS tape, I used 1/2" brads on the 'back' sides.
froglips
Jim Campbell
I use a bit of hide glue and a sheet of paper.
The hide glue can be dissolved by hot water or denatured alcohol.
The paper ususally gives out when I twist the pattern off the piece.
Hide glue tacks up quickly.
gazzer
Gazzer
Nails or screws if holes won't matter. Otherwise, I use carpet tape. This is a double-sided tape that is cloth rather than paper. It holds well (sometimes too well) and is relatively easy to remove. I just rub my thumb against it to pop up a corner and then roll it up and of.
-G
JackLeg
JackLeg
Reggie
Now THIS is what I call INPUT! :tinysmile_fatgrin_t
Thanx to ALL who have responded. It'll probably take me a month or more to try out all the suggestions. Thanx again folks!!:eusa_clap:eusa_clap:eusa_clap:eusa_clap:eusa_clap
