Source for 6" PVC (ASTM 2729) - Again
GeorgeL
George
Does anyone know of a source in the Triangle area that carries 6" thin wall S&D PVC pipe? (ASTM 2729) I have seen ASTM 3035 at Lowes but at $33/10' that is more expensive than SCH 40. I've talked to the special order desk at both Lowes and Home Depot but they don't have a clue.
It seems that I have blown my budget and will not be able to do the ultimate metal duct from K&B ($1400!)
Thanks for your help
George
scsmith42
Scott Smith
Ferguson's supply also usually has it in stock. They are a nationwide company with several locations (I think around 10) in the triangle.
Agri-supply would be hard to beat if they had it in stock though.
Thanks Dave,
Where is a JD Lanscape store located?
George
There is one branch located off Hwy. 64 in Apex near Lake Jordan, and another one just outside of the beltline near Capital Bvd. on Westinghouse Bvd. Either location should have or be able to get it. Let me know exactly what you need and I can call on Monday and get some pricing and turn-around time if they have to bring it in.
GeorgeL
George
Dave,
I need 50' of 6". I'll check with AGRI and Feguson's, if you could call JD that would be great.
Thanks again,
George
Alan in Little Washington
Alan Schaffter
Neither the Agri Supply nor Fergusons in Greenville carry 2729.
FYI, George or anyone need fittings, I have two 6-6-6 wyes and some other misc 6" and 4' fittings left over that I would let go cheap (got the 6" wyes on clearance at Lowes for $2.00 ea.!!!). If you want I could bring what I have to the picnic.
GeorgeL
George
Alan,
I definitely want the 6X6X6 wyes and would like to take a look at the other fittings you have. Please do bring them to the picnic.
George
George, I called JD today and I can get it for $1.44 a foot, 10" sticks. They don't have any in stock, but will be getting some by the middle of next week.
I can pick-up and deliver if desired.
GeorgeL
George
Dave,
Thank you so much for your help. I hope you didn't go to too much trouble. I found the pipe in stock at AGRI Supply in Garner (Thanks Wood nick!) It's about a $1 a 10' stick mire than JD but it's WHITE! I'm going to try to pick some up on the way home from work tomorrow.
By the way, Ferguson's in Raleigh does not carry 6" S&D and wouldn't even look it up for me.
The guy at AGRI Supply in the lawn & garden section (where the pipe is) said they didn't carry it. I took it upon myself to walk out in the yard and found 900 feet! They don't carry 6" fittings.
George
No troubles or problems. I do believe that the pipe from JD is green, guacamole green :wconfused:
I am just glad that you got what you needed :icon_thum
Dave,
I've never seen any D2729 S&D pipe that is [guacamole] green -- are you sure that is not SDR35 (D3034) pipe? That is typically green in color and comes in either gasketed or bellend versions. Its walls are thicker, but OD is identical to D2729. Like GeorgeL, I prefer the WHITE stuff because it matched the fittings and is lighter in weight. I'm also happy to hear that the prices have not gone up significantly -- I bought 140 feet last October for $15/10' length, which is very comparable to the prices mentioned here.
Dave,
Not positive that is was green. My rep said that he thought it was but gave me the price based on the specs not the color. What they have is exactly what George asked for, color is just speculation.
