What is that?Sketchup is amazing, but one key thing is hindering me...
I can't seem to get text ON faces. Text objects seems to float in 3D space and get hidden as I pan around the object.What is that?
I'll reply to this anyway but we can save other questions for the session. Text of the sort you're referring to gets inserted either as a label if you anchor it to some geometry or as "Screen Text" which is anchored to a fix location on the screen. Here's an example. The red text is screen text and the blue is leader text.I can't seem to get text ON faces. Text objects seems to float in 3D space and get hidden as I pan around the object.
Having said that - thanks for asking but I didn't intend to turn the thread into a Q&A session. Hopefully, you'll entertain questions during your training session, if it comes together.
Maybe you could put that in a thread that isn't specific to SketchUp.I've converted to Fusion 360. It universally works for all my equipment: 3D printer and Shaper Origin. I'd be interested in an online Fusion360 session!
I am interested too.I'm willing to do online SketchUp instruction.
If you want to put text on a surface within SketchUpm you can do that with 3D Text. Just set it to not be extruded.
If you have SketchUp Pro and use LayOut, you could add the text in LayOut instead. It would look better and you'd have more control over its appearance.
Understood. There's a lot of difference between the free web version and SketchUp Pro.Question - in your Flickr library are you rendering most of those models using a 3rd party extension to Sketchup Pro?
