I'm working on my shop door (34" X 80" X 1 3/8" thick* interior door)- raised panels lower section, divided light upper section, solid oak stiles, rails, and panels. The stiles and rails are cut and profiled. I didn't have a big door bit set, but by removing the slot cutter from a rail bit I was able to use a standard profile cabinet door stile and rail set. Actually, it worked quite well. Just so my panels wouldn't be too thin on the edges, since I need to run a raised panel bit on both sides, I set it up so the groove came out to be 1/2" wide (it is roughly 3/8" deep). I'll trim and profile the panels this morning and make the divided light grid later.
Now my question/problem- the top, middle, and bottom rails are roughly 4 1/2", 6", and 9' wide, but the mating grooves/tenons are only 3/8" long X 1/2" thick (no long tenons). That will not be enough glue surface to hold this heavy, full size, door together.
What is the best way to hold it together?
Options I'm considering:
(1) Glue up the door, drill through the door edges into the rails and use multiple 3/8" or 7/16" X 8" dowels (I'll need to get a long 8" - 10" bit- I can use my big box Father's Day gift certificate
(2) Drill, countersink, and install some long lag bolts (could interfere with lockset.)
(3) Use the mortiser to cut 1/2" thick X 4" deep (? limited by chisel length unless I use a Forstner bit and hand chisel) mortises in the stiles, use the tablesaw and tenoning jig to cut matching mortises (actually though-slots) in the ends of the rails (TS blade limits depth to about 3"+ deep), then make up and glue in some 1/2" thick loose tenons to join it all together. I would need to clamp the rails to prevent the ends from splaying since the tenons would be in a slot vs a mortise.
Even though it is more work, I'm leaning towards option # 3 since nothing will be visible on the door edge, unlike #1 and #2, and I think it will be stronger.
What do you guys think? Pics at 11:00.
* thickness is actually 1 11/32- I got a little carried away with the new planer
