I have bent a lot of 1" diameter red oak, white oak, and hickory with success. Any wood with good bending properties should work reasonably well. Selection of the material is a huge part of the success. Straight grained, green, riven material is the goal. I do not think any wood has 100% success----white oak has a 97% success rate according to the millwork book I have. In addition to those already mentioned, ash and hackberry are noted for good bending properties. My steam bending experience is limited to windsor chair parts such as the back bow, continuous arm, and crest for combbacks. I use a propane burner with a 5 gallon metal gas can (new never used for gas) with a radiator hose to carry the steam to a 6" PVC steam chamber. Each end of the chamber is plugged with 4" thick foam so it does not build pressure. Usually 20 minutes steaming after getting up a full head of steam is enough with green wood to allow me to bend successfully. I have not bent anything with as tight a radius as I picture a walking stick to be. Good luck with whatever you try .
Jerry
