Rust Alert for 1/21/12 in the Piedmont
Tarhead
It is 48f with a 44 dewpoint tonight in the Charlotte and Piedmont. Forecast is calling for 60f with a rising dewpoint for tomorrow. If you are not heating your shop above ~55f tonight and tomorrow morning keep it closed. Your cold Cast Iron will condense water like a glass of Ice Tea in August if you open it up tomorrow afternoon and it is below the Dew Point.
eyekode
Salem
Thanks Bruce! I used my IR thermometer on my cast iron this morning. I was in the green but still turned on the heater for a few hours to be sure :).
ehpoole
Ethan
Just an FYI with regard to IR thermometers and reflective surfaces. When you aim an IR thermometer at a reflective surface (such as polished cast iron) you don't actually record a temperature for the reflective surface. Rather, you record the temperature of the surface being reflected off the reflected surface (such as a ceiling or wall).
