Ed (nelsone) & I took a road trip to Cassatt, SC this morning to visit Susan (BKind2Anmls) and look over her new bandsaw acquisition.  We got there and immediately proceeded to take the thing apart!  Susan took notes on what we were doing and helped us.  This is a nice bandsaw and just needed a little TLC to bet it back to life.  The first thing we did was open the blade guards and see if everything turned free.  It did, so we released the blade tension and removed the blade. The table came off easily and with an ROS, Susan should have it sparkling in no time.  We found that the upper blade guide shaft had seized.  A little WD40, some sandpaper, a mallet and an oak dowel and off it came, along with the mallet head (it didn't hurt).  The blade guide pinion knob was missing a roll pin.  No big deal. The thrust bearing was also shot.  Not a major issue either.  It appeared to be a standard size that would readily be available on the net.    That monster 2-1/2" blade had some surface rust, but with some careful application of a sanding sponge and a sharpening it will be ready for action.  The motor turned freely and when we plugged it up and turned it on away it went.  I believe someone already said this motor was a screamer.  That was an understatement, but I have circular saws that make more noise.
Susan plans to rebuild the wooden roll around base to make it stationary & solid. We suggested she put in a dust port when she does. She says she will use it mostly for resaw and veneer, and it should suit these purposes perfectly with a 12" capacity.
BTW, here's the proof:
We would have taken more pics of the shop but I figured I'd let Susan do that when she was ready. It promises to be a very functional work area. All in all, an enjoyable morning for Ed & me and I hope a benefit to Susan.
