Brushing lacquer is not a good way to apply the product. After 40 years of spraying the stuff, I've never brushed on lacquer. Buy yourself an inexpensive HVLP spray gun and have some fun learning how fast to move down the wood to coat it. Keep the gun at the same angle to the wood and cross step down the you project at the same distance from the wood. Use a 30-50percent overlap and you will be surprised how little a learning curve there is.I have applied three coats of lacquer to some wood and lightly sanded between coats. I am using Miniwax Clear Brushing Lacquer. However, it keeps getting very rough spots across the board. What should I do to prevent this? Thank you for any suggestions. CyntO
Mark, what I have found over the years is a good quality old school Nitro lacquer is better in the long run. You can go back and touch up scratches a lot easier than the pre cat lacquer. Although pre cat is a "harder" finish than nitro lacquer.I have an HPLV -- that I rarely use. For the work that I do, I usually turn to Mohawk pre-cat lacquer. I do usually seal with Zinsser shellac before spraying the lacquer. Its more expensive -- but less time to clean up. My time in my shop is very limited -- so I am willing to pay a little more for more time.
I will have to give it a try. Not used it before. Thanks!Mark, what I have found over the years is a good quality old school Nitro lacquer is better in the long run. You can go back and touch up scratches a lot easier than the pre cat lacquer. Although pre cat is a "harder" finish than nitro lacquer.
