After seeing Alan in little Washington's central shop vac setup here, I decided to give the Oneida Dust Deputy a try to see if I could set up a similar system. I got the Dust Deputy assembled and tested this past weekend and it works good.
The yellow drum in the back is a Thien separator I have been using. Time will tell which one works better. I do know that the Dust Deputy will need to be emptied more often with that 5 gallon pail. The Thien separator is mounted in a 20 gallon carboy.
