My new shop: A work in progress
Rwe2156
DrBob
Dirt work is complete. Concrete work is complete. I’m on to building the floor. Supports and hangers for floor joists are in place.
Before I actually install the joists, though, I’ll put in under-floor duct work for a dust collector. I opted for the Oneida Supercell. It’s probably a little more power than I absolutely need, but installation is easy with flex hose, and the system will be easily reconfigurable.
I’ve drawn a layout for shop tools, and know where I want ducts to come up through the floor. If I change my mind, connections to each tool will also be made with flex hose, so it could be changed.
All of the parts except the dust collector itself should arrive in a few days. With a productive weekend, I’ll have the ducting in place and will be ready for an actual floor!
I recommend you give some thought to the under floor ducting. You never know if you’ll add a machine, or change the locations after you use the shop a while.
Going under the floor to the table saw is the best thing I ever did.
Also be aware I heard the Supercell is pretty loud.
I don’t recommend outlets in the ceiling unless you’re going to follow a duct to the machine.
areevesnc
areevesnc
Aaron
Some progress since my last report: I’ve completed installation of the underfloor duct work for dust collection. The people at Oneida tell me that their flex hose and T fittings will work perfectly with a Supercell for the runs that I have. The longest run in the new shop is about 40 feet, and the Supercell is supposed to handle more than twice that. Installing the flex hose and fittings required some patience, but I’m very happy with the way it turned out. Oneida’s fittings are a little pricey, but they appear to be high-quality and should last the rest of my lifetime.
Next I installed the floor joists and cut pieces for the plywood subfloor. The subfloor is not yet permanently affixed, and still needs holes cut where flex hose will come up through the floor to each tool. I also want to run most of my rough wiring beneath the floor to reduce the lengths of wire required, and for installation of in-floor receptacles. Once all of that is complete, I’ll put in some insulation before putting the subfloor down permanently. In the meantime, I have something I can stand on while I install framing on the walls between the 6x6 support poles.
Some pieces of the floor/subfloor will be removable, in case I ever need to get to the ductwork. I hope that’s a rare occurrence, but it will be possible if necessary with relatively little dismantling.
Finally, I started digging a trench for installation of new electrical service. Right now, the building is served by overhead wiring and a 20-amp panel. The overhead wiring continues another 200 feet to the house’s well. The wire and support poles are at least 40 years old, and beginning to show worrying signs of decrepitude. All of it will be replaced by an underground installation, with 200 amp service to the shop. I’m trying not to think about what it will cost to install new copper all the way to the well. The conduit alone was bad enough.
Charlie
Charlie
Aaron, Looking good. You will soon be making "fun" sawdust, not "work" sawdust. Lol.
areevesnc
areevesnc
Aaron
I reached a significant milestone today: the outdoors is now unambiguously distinct from the inside of the shop. I replaced the large sliding barn door with double doors, installed a window, and sealed up the wall.
If I were to do it again, I might go for a larger window, but I’m not going to complain… or do it again!
areevesnc
areevesnc
Aaron
After spending most of the winter on projects in the house, I’m finally back to work on my new shop. I’ve now cut spaces for and installed two additional windows, and have almost completed installation of framing between the poles that support the building. The framing will facilitate a substantial electrical service upgrade, as well as insulation. Once framing is complete, I’ll tackle these two tasks next.
In addition to working on the shop itself, I have also started working in it on a couple of small projects. I needed a large space out of the wind and snow today, and the shop fit the bill nicely. There are even plane shavings on the floor now!
areevesnc
areevesnc
Aaron
Next major milestone: new upgraded electrical service is in place. I now have the same number of outlets (2) running on the new service as there were in the entire building on the old panel. Enough that I can finish the framing and rough in the rest of the electrical installation.
areevesnc
areevesnc
Aaron
More progress. My brother was visiting from PA for a few days, so I’d have a little help. I installed ceiling joists to support drywall, and completed the rough electrical work for lighting and a few ceiling outlets for possible use with fans, air filters, or infrared heaters. Between the two of us, we then got drywall up and insulated the ceiling with some thick R-30 rolls. The building is already noticeably cooler during the day.
Every time I install drywall, I say it will be the last time. Using a drywall jack for the ceiling made the project considerably less painful. I’ll remember that for the next last time!
Next up: completing the rough wiring in the walls, and installing my dust collector.
