http://www.harborfreight.com/75-watt-magnetic-base-light-90766.html , might be nice to have on a bandsaw or d.p. if you don,t already and with 20% off coupon make the deal sweeter
It is not bad if you like LED lights. I prefer the old tungsten or quartz lights.
Will this lamp stand up on a wooden table, or does it require a magnetic surface?
Re: Magnetic Base Lamp $7.99 @ H.Freight
I have three of those in my shop. The only thing I found is that the 'socket/switch' combo will break down fairly quick (six months to a year depending on use). However, you can buy a good 'socket/switch' at the BORG for about $3. Still about a third of what you pay at any woodworking store. Good deal overall.
George
Perhaps some of the magnetic paint that is sold at one of more of the BORGs would help in this matter.Re: Magnetic Base Lamp $7.99 @ H.Freight
Would it increase base life if a CFL bulb were used? Incandescent lamps generate so much heat that the bases on many lamps fail unbeknown to the owners - usually from using larger than recommended wattage bulbs or inadequate ventilation.
I suspect that it is heat break-down so a CFL would probably help.
George
