Lessons from wood plane
tvrgeek
I had a thought. The wood Jack I got is very different. Glides way better. Sometimes the lighter weight is an advantage, sometimes not. Once upon a time they made hybrid planes. Metal frog, wood base.
Has anyone tried a different take on a hybrid? Just glue a veneer to an iron plane? Get the advantages of easy adjustment, mass of the iron, but glide like wood? Might try this on my Bailey. Reversible.
I also thought about screwing a broader baseplate to the side of a 5 or 7 for a shooting plane. Not as tipsy. Yea, if I won the lottery, I could afford a Veritas or LN shooting plane. Not gonna happen. :) But I do have some 1/2 inch aluminum plate. I ordered that funky handle from Cosman, as one might guess a Memorial day sale,
Mind wonders while waiting for glue to dry.
Cuthriell
Cuthriell
Agree on the shooting plane. I have a piece of 1/4" steel screwed to the side of a Sargent 6 size plane for a shooter and it is stable. If you did not want holes in the plane epoxy should work. I don't care about the holes and they have been there at least 20 years. Your board will need to be made for whatever thickness you add to the side.
Rwe2156
DrBob
I use a #6 for shooting. Tipping isn’t a problem you just have to get the ergonomics and forces figured out.
Some people fashion a knob made to fit the hand that attaches to the side. I’ve never seen the need but if I did a lot of shooting I might consider one.
Metal planes glide just as easy as wood if you use some paraffin wax on the sole.
Here‘s a video link to a pretty nifty shooting set up and you can see the knob on his, too. Cosman sells the knob.
tvrgeek
Wax, oil can, Magic ceramics, whatever. Quite a difference in guiding. Totally a different feel. I have yet to try the historic stance. It may work on an iron plane too.
Holes are not an issue. My planes are all users, no collectables. I am well aware of Rob's grip. After making several similar, I just splurged and ordered his.
On mass, I find when I reach for a smoother, I grab my old Bailey, not my new fancy WoodRiver. It may be just that it was my only plane for 40 years and I am just programed to grab it. Really, for a smoother we are taking such light cuts I don't think the extra weight is any help and I find I no longer adjust the frog having a dedicated scrub and a couple of #5's so it being a Bedrock design, no big deal. For shooting, mass makes a big difference. I moved from #4 to #5 to #7. Some thinning of the till may be coming. I don't keep tools I don't use. I would love to try a new Primus smoother, but not for the money!
tvrgeek
Finally got it shaving half a thou. Practice and finding the right weight hammer. Then I added a little more camber to the iron and adjusted it as a fore plane should be.
Got me thinking. When we use a power jointer or table saw to edge boards for glue up, they are 90 degree and flat. Very flat. Is that really good? The tiny amount of camber on a plane iron could give a compressible edge to the wood that when clamped, draws the seam that much tighter. Does that make sense?
