How to put a sharp point on a dowel?
sapwood
Roger
I don't have a lathe, but figure there has to another method for putting a reasonably sharp point on the end of a 1" hardwood dowel, so it can be driven into the ground easily. You know, like a pencil sharpener!
Sander takes too long. Can it be done with a TS, BS, DP, router (not in table), jigsaw, handplane, biscuit jointer ??? ???? ???
Curious,
Sapwood
kota62
Gary
SapWood...
I use a cordless drill and my tabletop belt sander, run the drill fairly slow and it seems to work better, higher speed causes it to bounce... (When i do the 30mm wooden tips for shadow boxes this is how I finish since i don't have a chuck for my lathe). I drill a small centered hole and drive a de-headed screw into the end for the drill to grab onto
Good luck
Gary
If it is going to be driven into the ground, I would use a hatchet. We used to make our own tent stakes back when I was in Scouts. About 4-6 chops with a sharp hatchet and you had a point sufficient enough to drive into the heart of a vampire.
Or a draw knife would work. A spoke shave would work also, but it might be slower.
T
toolferone
User not found
Mike Davis said:
Doesn't anybody carry a pocket knife any more? :roll:
I am naked8-O without one. That and a small tape measure and my watch, and I am good to go.
sapwood
sapwood
Roger
Hey, I was in the Boy Scouts (Tenderfoot :lol:) and the Marines (grunt) :oops:, but I was looking for a more "elegant" solution. Besides, it's a FIL Day's gift and I would like the 4' x1" hardwood dowel that accompanies it to look sharp! (Especially since he has about 50bd ft of 1" thick eastern red cedar he may give me :eusa_pray)
Actually, I dimly remember reading somewhere about doing this on a TS or router . . . but so many of my memories have dimmed :crybaby2:
Sapwood
A bench grinder works in a pinch. Depends on how smooth a wheel you have on it. A drum sander in a drill press will also do the job. Set the drum just above the DP table and hold the dowel at a 45degree angle from vert and rotate it into the drum surface. (Hope that makes sense!)
User not found
Roger,
Fastest way is with a stationary belt/disk sander -- clamp a block of wood on the table at about 30º from the disk face -- Use a 50 to 80 grit disk. Turn the dowel as you press it into the spinning disk. If you don't have a stationary belt/disk sander but you do have a belt sander, install the coarse belt and clamp the sander inverted in your bench vise. Lock it on and eye-ball the dowel angle at 30º into the turning belt and rotate to make the point.
walnutjerry
Jerry
Curious,
Sapwood
Hire a beaver????????????????? Jerry
sapwood
sapwood
Roger
Thanks for all the suggestions pointed out :icon_thum
I look forward to experimenting with them. . . well most of them. ;-)
Bladeburner, I don't think I have the uh, cajones, to hold onto a dowel that's inching toward my TS blade :mrgreen:
Yep, Mike I always carrying my trusty Swiss Army pocket knife.
'course I mainly use it for removing splinters and dental hygiene :lol:
Sapwood
