Help with Texas Star
skysharks
John Macmaster
Hey all
Got any thoughts on this project. My LOML is into Texas stars. I would love to make her several of different sizes, but I am unsure of the angles on the legs of the stars and then joints in the center.
Has anyone run into this, or any ideas?
cskipper
Cathy
Sorry, I'm an Okie! :lol: We don't "do" Texas. Seriously, I'll look around - seems like I've seen a pattern.
skysharks
John Macmaster
thanks Cathy
My wife would love it if I could do a few.
Oh and tahnks chris for the angles, I will keep those in mind.
MikeH
Mac are you looking for something like this?
skysharks
John Macmaster
Yep you got it on the nose.
The wife finds them all the time made out of metal.
I was thinking that it would be real cool to do some out of contrasting woods, ie maple and walnut, oak and walnut, etc.
Its the angles on those legs of the stars and the raised effect of the center line of each star leg, then joining them all in the middle has me scratching my head. That's why I dont have any hair :rolf: .
But then again the good lord only made a couple of perfect heads, he put hair on the rest:eusa_danc :eusa_danc
MikeH
I think the contrasting woods would be awesome. Somebody correct me if I am wrong, but a circle has 360 degrees and there are 5 points which means each point is 72 degrees apart. Divide that in half for the centerline and you have 36 degrees. I would draw it out and make templates or better yet just print the star out and use it as a template.
Make sense?
cskipper
Cathy
These would also look great with just one type of wood - with the grain running opposite directions in each "arm".
Jim Murphy
Fern HollowMan
Draw a circle of any desired radius. Draw a line from the radius point (the center) to any point on the circle.
Using a protractor, lay out a 72° angle and extend the angle to the circle. Continue around the circle. You should have five wedges, each being 72°. Connect the circle dots.
If you want to make a large star, you might consider using my friend trigonometry to define the angles instead of a small protractor.
The tangent function is your buddy, and it's available on your computer's calculator. Make sure you have selected the scientific calculator from the VIEW tab.
If you key in 72 and then press the TAN button, you will see this monster: 3.0776835371752534025702905760369
This is relationship between two right angle legs and a 72° angle.
Draw a line up (north) from the radius point through the circle.
Measure up this line (north) 10", mark it, then put your square along the line and from the 10" mark, go out right (to the east) 10" X 3.07, or 30.77", which is 30- 3/4" close enough for this. Connect the endpoints and that's real darned close to 72°. Check this with your protractor (measure twice, you know).
Now, take your dividers and measure the "chord", that is, the straight line between where the north line and the 72° line intersect the circle. (This would be between P and Q in Figure 2.) Walk your dividers around the arc, and you're setting off exactly even angles. Mark those tick marks and connect the dots.
Trig is very helpful in getting things much closer when you work with large dimensions where a tiny protractor introduces significant error. Sort of the old 3-4-5 deal.
I spent 35 years doing this stuff, if y'all want any help on how to layout using geometry and trig, gimme a shout.
For the raised ridge down the center of each point, you will be running into a compound miter situation, but you will need to know the thickness at the center point of the star to make any calculations. If I was doing it, I wood set the wood on edge and cut the bevel angle on the wood first with the TS blade tilted to the desired degrees. Then it would be fairly simple to make the remaining cuts with the blade at 90.
If I calculate correctly, each "half-point" section will have an 18 degree angle from the point to the center. For a 10" radius star, pick a point on the edge and draw a line at an 18 degree angle. Measure 10" along the angle line. That will be where the finished piece will meet the others at the center. If you want the star 3/4" thick at the center, then tilt your blade so it is 3/4" over at that heighth (distance from edge to your 10" mark). After the piece is beveled, return the blade to 90, and cut from the tapered edge along a line at 18 degrees. measure on this cut edge 10". cut another miter of 37 degrees from this point and the 10" line, and you will have 1/10th of the star made (in Mikes illustration, it would be one of the dark pieces.. For the opposing piece you will have to swap the angles in relation to the beveled edge.
One way to try
dick541
dick cunningham
I built a star for christmas several years ago. Just take 5 pieces, all 5 must be the same lenght and connect all the ends and you have a star.
dick
skysharks
John Macmaster
Pete you may laugh but That is what I was saying in my head when I read it .
Oh my head hurts reading all that.
Of course to the author it probably makes all the sense in the world.
But if I don't have pictures to go along with all that, i'm afraid I would be lost. I'm just a country boy that likes to make saw dust and stuff
Sorry:-(
I'll have to digest all this stuff realllllllllll sloooooooooooooow.:eusa_doh:
sapwood
Roger
Man my head is spinning and I'm see stars :drunken_s
Think I had better lay down for a while. :oops:
Roger (English major)
NCPete
Pete Davio
sky is overcast here, can't see no stars! (foreign language/business major, long ago engineering student)
