I'm fairly new at this but have had no issues with Freuds industrial 10 from Klingspor. I just use it for splins and rabbets and dados for box bottomsLooking for opinions on recommendations for a flat top grind 10" table saw blade ? Not wanting to break the bank here as it won't get used much.
Thanks !
I didn't clarify "breaking the bank" as I'm not sure what decent blades recommended prices typically are. I would think $120 is breaking the bank...I'll look into the other brands (other than Forrest as I know they'll be expensive). Thanks !I love my Ridge Carbides FTG. Not sure what your definition of breaking the bank is, but I paid $120.
Just like you, mine doesn't get used much, but when it does, it's enjoyable to use.
Are you looking for thin or full kerf?
Not a dado stack just the single FTG blade, thanksAre you looking for a single blade or dado stack? The Infinity is supposedly pretty good. All blade manufacturers (Forrest, Freud, Whiteside, Amana, Ridge Carbide, etc.) have a version. Also, if you have a spare blade due for sharpening, you can have it sharpened with a flat top grind.
As an owner of a similar Delta saw, I don't think the saw will have any problem with a modest depth kerf even with a full width blade. If the full width cut fits the plywood, it should be fine.Looks like CMT & Freud have both thin and full kerf FTG blades for $50-57. However, they claim 1/8" for full kerf but list as 0.126" vs 0.125".
Question: For small projects (using a 1hp older Delta 10" contractor saw), if I'm trying to get a 1/8" groove or dado for 1/8 birch plywood do you believe it's best to go with the full kerf blade or go two passes w/ the thin kerf (3/32") to dial in the fit.
My dado set only has flat top grind blade for the blade inserts (the ones you sandwich between the outside blades) and they only have 2 cutters...I believe it's unsafe to use that while my outer dado blades have the cutters beveled in towards the middle. I was hoping my Dado stack outer blades were flat top but they weren't.I just use a blade from my dado set. What am I missing?
Those do look nice as well but I'm trying to get a 1/8" cut and those seem to have a min of 1/4" kerf (in a quick search). Their "chippers" are 1/8" but only have two cutters as I call out above so same basic issue as my dado stack.I (and others) find a box-joint set useful for many other cuts. The cut is square and generally splinter free. Both grooves and dados are neatly cut. Use one or both blades as needed.
Several manufacturers make these sets and they cost around $100.
I rarely use my dado set any more.
My favorite. Have used these for at least ten years. True flat grind, and reasonable price. The Freud 24 tooth flat grind rip blade. I use the thin kerf 3/32” one.Looking for opinions on recommendations for a flat top grind 10" table saw blade ? Not wanting to break the bank here as it won't get used much.
Thanks !
10-Inch 24 Tooth FTG Ripping Saw Blade with 5/8-Inch Arbor and PermaShield Coating $43.95 Amazon 9/1/2024 14:25 HRS Also "CMT Orange Chrome 10” Carbide Rip Saw Blade, 24 Teeth, Flat Top Grind (FTG), 0.126” Kerf 285.624.10 Current price $49.72 Ostensibly 50% off at this sale price)"I didn't clarify "breaking the bank" as I'm not sure what decent blades recommended prices typically are. I would think $120 is breaking the bank...I'll look into the other brands (other than Forrest as I know they'll be expensive). Thanks !
