Chair Scoop Using Table Saw
Wilsoncb
Williemakeit
I decided to try a chair seat scoop on my table saw based on a YouTube video I found from Mario Rodriguez. The video is about 10 years old and after I got into it, I found some minor details were missing. I figured out the missing details and gave it a try. After doing my first one, I found the V-notch used to pivot the seat didn't result in a consistent shape. I played with the shape, but ultimately, it doesn't hold the pivot point well enough for the final shape. The solution I came up with works, but it's a bit clumsy. You will see in the pictures I used a removable pivot piece that is located with pins and held in place with a clamp. It works OK because you only need to use it for the first and last cuts. If I were to do it again I would make a pivot piece like I show in my drawings. That piece could be hinged, or slide back on forth to make it easier to operate.
Below is a link to the Mario Rodriguez video and some pictures of my setup. I've also attached some drawings with all the details. I made .pdf files of the drawing in both color and black and white. I thought the color version would be nice because it shows each piece in a different color, however I found it was harder to read. You'll also have to excuse me for using decimals, but after years of working that way...that's just how I roll.
Claus
Claus
I’ve seen that video and a couple others with the same concept. Kinda left me scratching my head. I appreciate your write up and comments/additions.
How did the seat turn out? I’d love to see some pictures of that.
thanks
Wilsoncb
Wilsoncb
Williemakeit
thanks
Thanks, I’m not done yet, but here are some pictures. One is just after the blade depth was set. The other is after completing and sanding. I still need to cut the seat to the shape I want.
klitscher
Sorry to bring up an old thread, but I found it having watched the video on youtube and have been unable to find the original plans for the jig.
Did you find the chair comfortable? Do you have a copy of the plans you could send me? You mentioned a pdf, but I didn't see them. Thanks for any help you can provide. Hoping to start a dining room set in the next 6 months.
Wilsoncb
Wilsoncb
Williemakeit
I would say, it's not much more comfortable than a flat surface. If you want improved comfort, you would probable need to go deeper and do some hand carving. That would require a little thicker material in the seat than the 1" I used. Here's a final picture of the chair. If you would like the chair plans, let me know I can send you either AutoCad file, or .pdf of drawing.
Dj Bounce1
Dj
I am in the process of making 4 chairs I would appreciate your pdf files as I want to attempt. to make that seat. Thank you
Wilsoncb
Wilsoncb
Williemakeit
Dj Bounce1
Dj
I clicked on the download ,but only received the pic. Is there something else I need to do? I went beck and looked at the pictures on the post. I understand how you modified it. I am going to give it a try.
I enclosed a couple of pic of the coffee table, wall shelf I made. Thanks again
jlcrtr
James
Wow. Very cool and your chair is beautiful.
