In my shop, tools MUST be on wheels. I just don't have the space. So, I ordered the same wheels I'm using on my larger bandsaw from Great Lakes Caster. I ordered knowing I might have hole size issue and other issue ... but figured I'd work around them.
And ... I have two issues.
1. The holes in the cast iron legs of the Powermatic lathe are too small for the 12mm threaded bolt needed for the casters. The legs have a threaded, smaller, hole for feet it came with. I am going to want to change that, but was concerned about drilling into the cast icon -- could it break? I've heard it's fragile. What's the best method to safely increase the hole size? The best bet would have it tapped to I could screw these into it, but I have no clue on doing that.
2. The Grizzly bandsaw has adequate holes, but they are 2 3/8" off the ground. I can buy longer bolts, but will that hold it ... considering 2 3/8" of bolt will not be used and will be unsupported (the wheels need to show out the bottom). Any suggestions?
Here's what I have...
