I saw this trick somewhere and remembered it as I was needing to refinish some Oak trim around a countertop.
The Oak trim was waterstained around the sink and dishwasher and looked pretty ragged. I needed to scrape off the 12 y/o poly finish and reapply a new seal coat.
Start by sawing halfway lengthwise through a 1/2"X13 nut with a hacksaw. Take some sandpaper through the cut a few times to widen it a little and smooth the edges. Slide it gently from the end onto your Card Scraper and screw in a 1/2" X13 Socket Head Set Screw. Adjust to the amount you need to scrape and Shazzamm...no more scratched countertop!
