Is that OK to do? I've normally used oil based poly as the last coat when I wanted to add durability to a table top or other surface I know will be well used.
I've tried a couple coats of Satin Lacquer (Deft brushing lacquer) on a test piece after a coat of Oil Varnish and it seems to be doing OK. Am I headed for trouble down the road though? Are the finishes compatible? I like the subtler look of the Satin Lacquer versus the shiny poly.
