Lest anyone thing I've been a little slack in my WWing endeavors this year, let me show you some of what I've been working on. This is a custom Wine Cellar for a customer of ours that we've been working on since March. In addition to the supervisory aspect of all this, I've done all the on site carpentry. With there being 12 steps into this cellar, yo can see why I nicknamed this project "The 12 Step Program". This is pretty photo heavy so if you're on dial up, be patient:
First, there's the entry doors. We took the original cellar doors and clad them with hammered copper and applied steel strap hinges and pulls:
"But wait!" you say, "Won't that make them too heavy to open?" Yes, it will, so we installed automatic gate openers and gas shocks to give them a boost. We also modified some old doors to make an entry into the cellar itself, although they don't show up very well here:
Then we put faux stone veneer and stone treads and risers on the steps and had to cut out and brace the floor rim band to get head clearance. The ceiling here is lowered to allow HVAC ducting to cross over above:
At the foot of the stairs we needed a place for the empties. It also doubles as a concealed door to the HVAC service area:
On the wall opposite we installed an old leaded glass window:
Once inside, I built a wine rack to fit the space. It had to be designed so as to be brought down in segments and assembled in the cellar with minimal head clearance after receiving a distressing and antiquing finish by others. The ceiling was made of rough sawn oak from Virginia. The T & G sections were made in removable panels for access to piping and equipment above. All finishes had to be water based to avoid possible hydrocarbon contamination of the wine:
The angle cabinet got a set of drawers instead of the sloped display rack. But we also added a full extension slide out counter below. Lighting is accomplished by a low voltage track mounted to the wall above the cabinet with arms extending out as much as 24":
Then on the opposite side we built a counter with arched stone top and sides back lit the shelves with LED ribbon lights (on a dimmer, of course). The top was milled and glued on site and then stained in place. The piece above the top is an antique relief transom that was fitted with a wine glass rack and mounted into the stone work. To the right is a copper vessel and basin mounted onto the wall:
The original wine rack they wanted to use was an antique that was disassembled and placed into the basement after the floor was installed and prior to the stone installation:
The entire space is insulated and climate controlled for temp and humidity. I may add some other pics later on, but this has been a challenging and enjoyable project for a couple of great customers for me. Although they weren't sure sometimes what they wanted, we were able to work through any issues and ultimately create the space they were looking for.
Thanks for looking.
Thanks for looking.
