1/4" plywood squares
J_Graham
Graham
I am in need of a few(12) 1/4"thick, 12"x`12" plywood squares. I would prefer not to break down large sheets for multiple reasons. I am not picky about the type of plywood as it will be covered. I have seen some for sale on here a couple of times as cutoffs, I wondered if I could get a few of them for cheap/trade?
Building a project wall of sorts for my quilter wife, so I'll be covering them in felt fabric. Thanks!
edit: Located near Raleigh, I'd be willing to travel a bit.
-J_Graham
Martin Roper
Martin
Do they have to be exactly 12"x 12"? Allowing for the kerf, you could get 8 nearly 12" squares out of one of these:
Wilsoncb
Williemakeit
I totally get it. I had to break down some full sheets of 3/4” & 1/2” yesterday. Even using a track saw it’s a chore to move the sheets around a small shop then working around them.
I know the Hardwood store in Gibsonville will break down a sheet for you. Just make sure Splintered edges. Generally they don’t, but one time I either got a bad saw operator, or the blade was not good. If you don’t trust they will hit your dimensions, just ask for it a little bigger and finish it yourself.
Henry W
Henry
Woodcraft usually has 1/4” Baltic birch in 12 x 12. Worth a check.
I believe Klingspor's has the same
Depending on your timeframe, I may have that many pieces of scrap 1/4 plywood (mostly reclaimed). Are you open to any type of material?
I am not certain that I have 12 pieces though. I will look around any try to follow up.
