I had four Klingspor sanding belts (3'x18"), two 150 grit & two 220 grit, for about ten years. Today I finally got around to using them. After 30 seconds of sanding, each of the belts came apart at the belt seam. :eusa_doh:No injury occurred, unless you count bewilderment. :roll:
Note: this question (or answer)will not be found in Trivial Pursuit.
