http://raleigh.craigslist.org/tls/1944259571.html
This is about 1/3 retail... seems like a steal if you're in the market for a RAS...
10-Inch 1-1/2 Horsepower Radial Arm Saw - $550 (Durham)
Date: 2010-09-09, 3:27AM EDT
Reply to: sale-tupu7-1944259571@craigslist.org [Errors when replying to ads?]
Cast-iron track, column and column support for rigidity and continued accuracy; Depth-of-cut control handle and locking levers are positioned above table for easy access; Extra-large table provides support for wide panels or large workpieces; Steel stand for sturdy support; Provides greater cutting capacity for cross-cutting nominal 2" thick stock up to 16" wide; Miter cutting capacities in nominal 2" thick stock are 10-1/2" at 45 degree left and 11" at 45 degree right; Dual-threaded shaft accepts a number of accessories to expand the use of saw.
- it's NOT ok to contact this poster with services or other commercial interests
