Good to know, Thanks Alan.
How about a 1.5hp with one of those separators? If it's not gonna work well, collecting the fine dust as well as the chips, Then I have got a 55 gallon white/see through drum to get rid of.
Matthew
Here is the deal- a simple analogy- have a friend who is a smoker generate a small puff cloud of smoke, then ask him to suck it up with a straw- hard to do isn't it? That is what is essentially happening around your tools unless you keep that puff of smoke (dust) from leaving the machine. That is why I say the important part of dust control happens at the machine, not at the separators or filters and why you need max CFM at the machine. You need an adequately sized blower and ducting. Also, every single piece of equipment- pipe, fittings, flex, separators, filters, etc. between the machine and discharge (both sides of the DC) generates static pressure (resistance) and reduces CFM at the source. So the ideal is to eliminate as much of it as possible.
The ideal system (most efficient at collecting the maximum amount of fine dust), if you live in the woods, is one which dumps everything outside with no separators, filters, etc. Since few of us live in such an environment we must make compromises. But there is no getting around Mr. Bernouli- you gotta have suction first then minimal resistance to effectively collect and control the dust.
To answer your question, a 1.5 hp system depending on design- impeller size etc., etc. and how you use it, roll-a-round or fixed duct system, and a separator, will work (one tool at a time) to a reasonable degree, as long as you don't burden it with too much or too small of hose/pipe and filters that clog- hence discharging the relatively chip-free (but likely fines laden) air outside. There is no "this works" and "this doesn't", it is all a matter of degree.
Just my 2 cents but I never intended for my dust collection set up to collect the fine dust that is generated, nor do I believe that it will collect the fine stuff. I use mine in conjunction with all the other equipment that is available, ie: dust masks, proper ventilation etc. I have just finished an air filtration system that should help with the fine particles so I believe that I am doing all that I can to reduce the amount of dust that I ingest.
That is a good approach. Just remember, the really fine stuff can stay airborne for 30 min.or longer and is easily disturbed and sent airborne again once it has settled on horizontal surfaces, clothing, etc. Unfortunately, depending on the filter stack, most filtration systems do not filter out the fine stuff, they just circulate it and keep it in suspension giving you more opportunity to breath it. You will find some sources that say a mediocre air cleaner is worse than none at all. A mask and good ventilation, however, are excellent strategies.
I'll finish with this comment then get off my high horse. Unlike previous generations, more hobby woodworkers than ever before:
- Own and more frequently use more high dust generating tools and machines- because they are more available to consumers than ever before, especially sanders (belt, drum, ROS, OSS, etc.), have more money to spend on "toys", and more free time to use the tools.
- Work in confined, sealed, and insulated shops vs garages where they too often try to recirculate the DC collected air rather than dump it outside (industry doesn't attempt to do that!).
You can't beat Mr. Bernouli, so listen to what he says and design your dust control system accordingly.
