I don't think it looks bad after painting - as we can see from the pictures posted. It is a shop after all. There is a smooth and rough side. As I mentioned, it is a bit of a bear to get a screw into it. I did not paint the lathe a different color but it is a good idea. If looks are that important you don't want to use it. My previous shop had plywood walls and after painting they did not look that good either - sure wasn't as smooth as drywall.
I am not sure about the glue/fume business. I can't detect anything so if there are fumes they are not noticeable. Of course I had the doors open all day for a couple weeks after installation. I can't believe it is out gassing for much beyond a week or so. I cut all the panels outside but there was little cutting as the walls are 8'. I put up all the 4' sections from the middle outward. Then only had to cut to width in the corners. But while we are on this, I use MDF to make patterns, etc, all the time and it is way worse than OSB for dust. So if someone objects to OSB dust they must really have a problem with MDF.
The painting difficulties were not enough to make me swear off OSB & given the same circumstances I would likely do it again.
