I have both the nova chuck and the oneway talon. The artical is right. The only problem is that the screw that holds the jaws are different for the two chuck. The talon screws are longer and have a larger head, but the same thread size. So you have to check to ensure that you nave the right screws (head size and thread length. If you use the wrong screw with a certain type of jaw, some times it will not tighten up all the way. In it will work for both chuck and jaws but you have to watchthat every thing in OK.
Gary
