Well here is another question. With the stock plastic table insert that comes with the saw, which is NOT zero clearance. I get blade deflection against the side of the insert, when I tilt the table past about 30 deg. I would think that the width of the slot would be wide enough so that didn't happen. Is there something mis adjusted? Or is that just the way it is. I understand that with a ZCI it is necessary to cut a special insert for each tilt angle.
