Hello all-
I'm working on finishing my coffee table, and after applying the first coat of Minwax Polyurethane on the sides of it, I've developed a number of white spots all over the piece. I've attached a picture for an example. I've been sanding with 280 grit after I stain prior to applying the poly...and applying it with a staining pad. I've finished the tops with this same method and they look great! After the 1st coat I sand with 320, and apply a 2nd, sand with 320, and apply a 3rd where needed.
What is this, and how can I get rid of them?
Thanks a ton!!!!!!!!!!!!!!!
