I am trying to make 3/8" check cuts on 3 1/2" wide tenons. The problem is the bandsaw is not cutting parallel. I have the saw set up correctly with a new blade. Blade is square to the table, table is square to the fence, fence is parallel to the blade, the stock is square but the cuts are off. They are wider at the bottom and narrow at the top. It is an absolute riddle to me. :BangHead::BangHead::BangHead: Any suggestions would be greatly appreciated. Take a look at the pic below for a visual.
