One of my Son's and one of my Daughter's asked me to make them a set of living room tables. So I decided to use some QS RO cull wood from the last lumber run. I came up with a very basic design that I threw together without any plans. The end table also has a low BF count of 11.9
* 1) top qty 1 - 1x8-8 (7/8 x 21 x 25) edge glued
* 4) legs qty 2 - 1x3-8 (1 7/8 sq x 23) face glued
* 4) rails qty 1 - 1x4-8 which will make 2) short rails (7/8 x 3 x 16 3/4) and 2) long rails (7/8 x 3 x 20 3/4)
* 4) corner block 7/8 x 3 x 4 leftover from above
* 28 2 1/2 drywall screws (to fasten the rails to the top and legs to the corner blocks)
* 12 1 1/4 drywall screws (to fasten the corner blocks to the rails)
* 3/8 round over bit (round over the edge of the top and outside corner of the legs)
The rails set back 3/4" from the edge of the top and the legs ~ 1/4". I have not finished sanding and sealing but here's what it looks like so far, after about 4 hours. Minus over night glue dry time for the top and legs. I have 3 more end tables and 2 coffee table to make.
And yes that's white paint on the floor, I need to refinish the floor still as you can see someone stained it :confused_
