I'd like to chime in and correct some mistaken perceptions...
There are four different commonly used methods of kiln drying, and they all involve totally different technology. In order of predominance, they are:
1 - conventional kiln drying (steam)
2 - Dehumidification kiln drying
3 - Vacuum kiln drying
4 - Solar kiln drying.
The bulk of furniture wood in the US is dried in a conventional kiln at high temperatures (160 - 180F). When walnut is dried in a conventional kiln, the steam causes the dark rich colors to fade, and the light colored sapwood to darken, and the end product is noticeably different than AD BW.
Both solar and dehumidification kiln drying is done at low temperatures - typically around 90 - 100F, which is fairly similar to air drying. Vacuum kiln drying is also done at fairly low temperatures.
Guys - I can place two pieces of lumber side by side that came from the same log. One air dried, and one dried from green in either a solar or DH kiln, and I would challenge anybody to be able to tell the difference between the two. For all intents and purposes, you cannot tell the difference between them.
On the other hand, if a piece of walnut from a conventional kiln was placed next to a piece of walnut that was air dried, the visual difference is notable.
I've had members of the Period Furniture Restoration Society tell me that DH kiln drying caused the color to bleach out of black walnut, and that the water draining from the DH unit would be a dark color. HOGWASH! The water coming from a load of BW in a DH kiln is clear as can be, and there are not discolorations or stains on the ground below the drains. Now steam kilns? Different story altogether.
When it comes to color and workability, not all kiln dried lumber is the same.
