Hey Folks,
Need some help or advice:BangHead: :BangHead: :BangHead:.
I'm trying to tune up my Unisaw (Right Tilt) and have been successful with all of the adjustments except getting the blade perfectly parallel to the left miter slot.
I'm using a 1/4" flat aluminium plate (Master Plate from Griz) and a dial indicator mounted on a miter bar. I set the dial indicator to zero at the front of the blade/plate and then move the dial indicator back. The best I can get it to is 6/1000" (I got here by loosening the four bolts holding the top to the cabinet and then tapping the respective corners with a wood block and mallet until I got to the above measure).
My question is; is 6/1000 of an inch the best I can hope for or should (in theory) I be able to get to zero (front to back)?
Thanks for your help.
Dan C.
Dan C.
