My wife and I are going to redo my shop area as a joint project. She is much better at organizing things and I think she is also going to keep me from cutting too many corners (my low budget is largely self inflicted).
I have about half of one bay where I basically have about 8'x8' that will always be shop space and where I will most often work. In the other bay, I have about 6' along the wall in front of the car and I can back the car out to use the whole bay when I need to. Right now, the big BS, the TS, shop vac and Thien separator are there. There are cabinets on the wall above the TS and shop vac where I keep shop related stuff. I also have one tall cabinet elsewhere on that wall.
There are two things we have pretty much decided on.
One is a pegboard cabinet, where you have a big door (to the cabinet) with pegboard front and back, another just like it on a second hinge and then pegboard on the back.
The other is a workbench against the wall with rollout cabinets or tool stations beneath it.
I currently have a benchtop TS mounted on a good tool stand and a 14" BS with riser as my only stationary tools (though I rarely move my benchtop DP). I have a CMS, but it isn't mounted; I pull it out, use it and put it back when done. I have a bunch of handheld stuff - circular saw, jigsaw, router, drills, angle grinder, rotary tools, etc. I have a little 9" BS I use sometimes, a grinder and a lightweight scroll saw. I will be building a small carving bench and I want carving tools easily accessible.
Anyway, I am looking for advice like "I wish I had (or had not)..." or "You might want to consider...". I am actually prying the wallet open for once.
