Not a review per se but I thought I'd mention a couple of programs I have been using for some time now and have been pretty pleased with their ease of use and functionality.
Cutlist Plus http://cutlistplus.com/ This is a layout program to optimize material useage on projects. You put in the dimensions of the parts and the material to be used and it generates a cutting diagram to make the best use of your material. You can specify if you prefer to start with rip or crosscut, kerf size, etc. You can also maintain an "inventory" with it and cost out a project. It works best with sheet goods but I have used it for lumber as well. Definitely has paid for itself several times over in time and material savings.
Delta Cad http://www.dcad.com/ This is a cheap and easy cad program that is quite functional and easy to learn. There are others out there that are more powerful but they are also more expensive and have a pretty steep learning curve. This a really powerful way to play around with designs and dimensions.
my $.02
Steve D
my $.02
Steve D
