I need to attach a couple of through tenons with double wedges for the cherry buffet I am building. I have never done wedged tenons before. When I researched it, it appears there are two different ways to do it: 1) angle the mortise to allow for the expansion caused as the wedges are hammered in 2) cut angled slots in the tenon to accept the wedges. The plan that I am using shows the latter way. It shows a square mortise with wedged chunks cut out of the tenon.
Here are my questions. 1) Which method is better? 2) How much do you vary the wedge angle for solution #2? - I couldn't find any details about this method. I am assuming if you made the wedged hunk the same size as the wedge, there would be no advantage to doing this.
Right now the tenon is a very snug fit in the mortise. I don't want to do anything to weaken this joint. Any suggestions would be greatly appreciated. Here is a picture of the situation. The mortise is about 0.70" deep.
Amy
Amy
