When I turn on the cold side of my faucets in my house, I get cold water at the very first and then it turns warm for several several seconds until finally turning cold again. This just started happening a few months ago. It has to be something going on with my electric water heater allowing heat up into the cold water supply. The cold water supply to the heater is measuring about 80-82F a couple of feet from the inlet nipple using my infrared thermometer. The cold water pipe gradually measures cooler as you move further along toward my fixtures. It is above 70F for at least 5 or 6 feet. The water heater is 14 years old and I have not changed the thermostat setting which is at 120F. The temperature and quantity of hot water is normal when taking showers, filling large pots, etc. Even though I already had a flexible, non metallic hose between the cold water supply and the heater inlet, I added a heat trap loop. When I made that loop, I added a plastic lined (heat trap) nipple even though the heater had one built in. The heat trap did not help at all.
I read online that faucet cartridges can go bad and allow hot water to pass to the cold side. I don't think this is my problem because it happens on all my fixtures and it sounded like when this happens, the cold side of the faucet is hot all the time.
The only thing that I think could have happened is that the dip tube for the cold water inlet on my heater has corroded and broken off near the top of the tank. Anyone else have any ideas?
