While they last:
http://www.ptreeusa.com/edirect_020811.htm
At $175 plus shipping I suspect they'll go fast.
Triton Dual Mode Precision 3-1/4 hp Router
Model No TRA001
$125.00 Off Regular Price Of $299.99
Your E-Direct Price $174.99
Hurry Only 200 At This Price !!!
Designed by woodworkers for woodworkers! From the ground up, the Multi-Award Winning TRA001 has been the benchmark in professional routers around the world since its release.
Key features range from a powerful 3-1/4" hp , soft start electronically controlled and variable Speed (with maintenance under load) provides the perfect speed for all cutter types, to side mounted cooling vents that ensure minimal sawdust entering the motor housing when mounted upside down in a router table.
The best ideas are often the simplest and the 3 stage pre-set height adjustment system is a perfect example of this. It only takes seconds to remove the plunge return spring which then allows for easy lifting and adjustment of the machine when mounted in a router table.
One of the most significant features of this machine is its ability to switch from conventional plunge router to a fixed based mode router with rack and pinion height adjustment with a simple turn of a dial. </H1>
Model No TRA001
<H1>Triton Dual Mode Precision 3-1/4 hp Router
Model No TRA001 </H1>
<H1 class=StoryContentColor align=center>Model No TRA001 </H1>
