Ok, I'm done pulling out my beard hair. I'm now confused.
Here is the situation, my shop is up on blocks, the ground slopes from right to left as you face the door. Due to a lot of hard work on my part, the shop is level.
Far right of the door, its 15" floor to ground. Far left, its 16 1/2" floor to ground. Door is ~4' wide.
So.......
Its too far for no step at all, I'm bound to fall.... again. I want to build a single or double step up. Thinking about a platform step, but thats not important.
I read up on stair rise/run stuff, but 7" stair riser doesn't give me a useable step size.
A. What do I do about the slope in the ground? Should I raise up the 16 1/2 end or dig down the 15? Do I even need to account for this?
B. What size step should I shoot for, given my ~16" total rise?
Three steps is ~5 1/3" rise, too short. 2 is 8", which seems a bit steep.
Yes, I am making this complicated, but sometimes I wanna do things the "right" way.
Last summer, I was using a concrete block as a step, it gave way, and I came down on my shin against the block. Left me with 3 rather nasty scars to remind me steps/stairs are important!
Thanks,
So.......
Thanks,
