As said, you do not need to use a special finish to "seal" the edges of a door. When painting, the best sealer/first coat is a thinned coat of whatever paint you are using. Thin it 25-30% with mineral spirits. Apply it and let it dry. Then apply the subsequent coats thinned 10% for better flow out. The door edges will be just as "sealed" as the rest of the door.
