A number of BT3100.1 saws made during late 2004 and first half of 2005 have switches which may stick in the ON position. The contacts are welding closed. The switch can be immediately rejuvenated by changing the leads to the second terminals revealed by removing the switch module from the cabinet. (four screws). Then send me a message to receive a free replacement switch with improved spring release pressure and improved plating on the switch contacts.
Because the switch will not "make" both sets of contacts at exactly the same time, there is no significant value to a jumper which would utilize dual contact sets.
Saw switches are high amp load, seeing close to forty amps at start up. It is not a good idea to wire a household lighting switch into a saw circuit.
Wayne Hill
Techtronic Industries North America, Inc.
(Ryobi)
Anderson, South Carolina
wayne.hill@ttigroupna.com
800.944.9577
pete
Wayne Hill
(Ryobi)
800.944.9577
pete
