I was sanding some fairly oily exotics today - leopardwood and zebrawood - and the paper on my Woodmaster drum sander now has a bad case of resin build up. Looks like the leopardwood is the culprit, since the buildup is the same color.
I've used the heck out of my crepe block, but the buildup is still really bad. If I stop the drum and manually scrub using the crepe, the build up slowly goes away, but it's s-l-o-w.
Is there any other way to remove the buildup ?
-Mark
-Mark
