I have been slowly trying to get a small shop together. A dust collector and shop air cleaner are in the shop waiting for install along with a small lumber rack also waiting to be finished. I have a question as to the weight of a trash can half or slightly over with chips and dust from the separator.
I usually don't turn or use green wood and not a lot of hard wood except where really needed.
So about what is the weight of a trash can of dust and shavings? The reason I am concerned is if the weight is not too bad then due to space it will be mounted on top the dust collector. A small area has a disadvantage so you darned sure have to use ALL the space you can.
This collector but the 1.5 hp version which is discontinued now I think.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97869
Thanks
Dudelive
Thanks
Dudelive
