The Woodworkers of Green Valley, AZ, www.WWGVR.org, is selling one its
Powermatic 3520B Lathes
$1,500.00
IF YOU'RE LOOKING FOR A GOOD, SOLID, PROFESSIONAL WOOD LATHE, AT A VERY REASONABLE PRICE, LOOK NO FURTHER!
It's about 15 years old. It has been well maintained on a regular basis, and is in excellent working condition.
We are in the process of upgrading our lathes to newer models.
We do not provide delivery as it weighs in at just under 700 Lbs.
Contact information regarding this Lathe:
John Hilborn - Treasurer
931-449-9202
HilbornJ42@gmail.com
Specifications:
Manufacturer: Powermatic
Model: 3520B
Distance Between Centers: 34½"
Maximum Swing: 20"
Speed: Variable in two ranges: 50 to 1,200 RPM; and 125 to 3,200 RPM
Horsepower: 2 HP
Volts: 220 VAC
690 Lbs.
It has a Tilt-away bed for easy tail stock removal!
The 2 hp heavy-duty lathe from Powermatic features a 20-in. swing, a 34-1/2-in. distance between centers, and variable speed in two ranges.
The Powermatic 3520B a heavy-duty lathe.
It’s known for ease of speed control, vibration, lathe movement, power, tool-rest design, and ease of adjustment for outboard turning.
The Powermatic 3520B is built like a tank, with the stoutest tailstock and the beefiest tool-rest base.
The Powermatic 3520B is solid even when turning a large, off-balance blank. The lathe won’t move when you begin turning a large bowls.
Local Green Valley Pickup Only
$1,500.00
931-449-9202
Specifications:
Model: 3520B
Maximum Swing: 20"
Horsepower: 2 HP
Volts: 220 VAC
690 Lbs.
