www.tooliday.com
PorterCable NS100B Factory Reconditioned 18Gauge Narrow Crown Stapler Bare Tool
Mar 19, 2010 01:00 am
The Porter-Cable NS100BBR Factory Reconditioned NS100B 18-Gauge Narrow Crown Stapler Bare Tool is a pleasure to use with plenty of convenient features and a comfortable rubber grip. The NS100B is also a breeze to use with its tool-free depth-of-drive and split-nose design that allows for easy removal if a staple happens to get jammed. If you're looking for a Narrow Crown Stapler that will stand the test of time, look no further than Porter-Cable's NS100B — it's built strong and made to last with a maintenance-free motor.
Features:
- Long-life, maintenance-free motor to keep from staining the work surface
- Internal piston catch for consistent max power on every shot
- Rear exhaust to keep contaminants away from work
- Drives 18-gauge staples with 1/4-inch crown from 1/2-inch to 1-inch length
- Tool-free depth-of-drive adjustment with detents for proper setting of staples
- Split-nose design for easy removal of jammed staples
- Sequential style trigger with lock off switch
- Removable non-marring nose tip with on tool storage
- Adjustable belt hook
- Integrated rubber grip for improved comfort
- Low staple reload indicator
- Special hardened driver blade
- Strong, lightweight, die-cast aluminum housing
Includes:
* Porter-Cable NS100BBR 18-Gauge Narrow Crown Stapler
Sale Price: $24.88 read more
Features:
Includes:
